Amsoil Oil Filter Update
I should hope they know without public input but maybe it was more of a care than knowledge thing if you follow
Thought their reply back to you was something along the lines that they had never heard about the ruffled leaf springs and resulting internal leak gap before? If they never found out about it, then they wouldn't have a reason to rethink the design.
@Pablo Dang it. Did you not say who is manufacturing the filters, or is it the whiskey again? The people around me keep telling me that it's over, and I need to go to an assisted living facility, so this is not going to go well for me if I missed something.
Thank you.
If this is updated it’s a new leaf spring design!! Also mentions some use a coil spring!!
Here's snap-shot that shows how those exploded views looked like on 7/29/2025, little over a year ago.
In this figure, they showed the two different setups, instead of noting it. The Amsoil filters made by Champion Labs as you know had the Fram style leaf spring with the bypass valve in the leaf spring.
So how does this compare to carquest premium?
Only thing we know if the box info is correct in the link in post 1 is that they are 99% @ 20u and rated for 25K miles. They will most likely be similar to the Carquest Extended Protection full synthetic filter.
