Delco PF48E low oil pressure
Originally Posted By: 4WD
Clueless
Without you hearing my engine with an aging AC Delco, then I assume you as clueless also.
Hear my engine with an aging Wix or Fram, then bingo, your clue light-bulb shines.
Originally Posted By: Triple_Se7en
Originally Posted By: DoubleWasp
GM has some wacky rationale for downsizing the filter for the LS engine that they really patted themselves on the back for.
This was mysterious to me, because GM traditionally used the largest filter possible for the application without scraping the ground in the previous generation.
Cars got PH30, trucks got PH5, and the medium duty trucks got something that looked like a Thermos.
I imagine GM engineers did some sort of "perfect conditions" calculation that figured a puny filter would do just fine, but the real world stepped in and screwed that up.
Cost savings is one of many reasons why GM vehicles look so cheap for the past 14-15 years. Smaller filters, no padding on inside door elbow rests.....etc..... c'mon GM.
This is what you wrote … now all this listen to your stuff run … ? Cheap blah blah
