Quote:
HDT was servicing their motorcycles with Mobil Delvac 1
5W-40 and using Mobil 0w30 racing oil for their race
engines. Mobil’s 0w30 is not diesel-rated or recommended
for motorcycle wet-clutch applications. “We have seen for
several years that our engines ‘like’ the lighter oils, especially
during initial run-in,” said Hayes. “This has been especially
evident when we look at camshaft and rod bearings after
a new engine has been run very hard with no run-in.” HDT
had been using Mobil 1 for three years, finding it was superior
to conventional diesel oil, but they were having problems
with blow-by.
Impressive Results
Hayes said HDT was drawn to AMSOIL because of the
availability of AMSOIL 0W-20 Synthetic Motor Oil and Series
3000 5w30 Heavy Duty Diesel Oil. “We noticed an increase
in horsepower right away as compared to Delvac 1,” said
Hayes. “But what was quite surprising was the condition of an engine after a 50-mile run-in and over 120 full-throttle
dyno runs. The camshaft bearings, the small and large end
rod bearing didn’t even look like they had been run. During
that series of dyno runs, we registered the highest horsepower
and torque readings ever.”
Quote:
“With over a year of testing, we
have found that AMSOIL products continually outperform all
other lubricants. AMSOIL provides improved performance,
increased fuel economy, lower oil consumption and significantly
reduced engine wear in all operating conditions.”
http://www.amsoil.com/news/2007_nov_bonneville.pdf
with blow-by.
Impressive Results
