The only amsoil in my area was availibe at napa. My nissan 240sx requires a weight of 75w90 gl4. This was durring a trans swap so I had to get something to get on the road.
The amsoil that was availible was the FGR longlife synthetic gear lube 75w90. I thought I was good to go. Its been about a week with the fluid in the transmission, however I stumbled apon some info that worries me. It seems the FGR is ONLY for diffs, not transmissions, and for the transmission the MTG aka the synthetic manual transaxle and gear lube.
Will running the FGR in my transmission that has brass syncros damage the transmission? yes the FGR IS GL5, but I dont know if amsoils diff fluid would work in the transmission.
Thank you!
PS I plan to order the MTG, however I just need to know if the FGR will work for a couple weeks.
Thank you!
