Amsoil EaO-13 Filter in 2004 Honda Odyssey
AL
The other day I changed the oil on our newly acquired 2004 Honda Odyssey to Amsoil 0W-20. According to the Amsoil website, it requires the EaO-13 filter. When I went to change the filter, I discovered that the old filter (VO-39 from Valvoline) was quite a bit larger in outside diameter than the EaO-13 filter with which I replaced it. Everything seems to work fine so far, but I'm a little concerned about the difference in size. There's quite a bit of overhang of the filter flange over the filter (probably close to 1/2-inch radially).
Have any of you with that generation of Odyssey noted any concerns with this filter? Any leaks show up later? Any concerns with the size differential? I know Amsoil uses nanofiber technology, but still...
That is the correct filter. When we had an Odyssey that is the filter I used. Chances are that whoever put the Valvoline filter on there used the wrong filter. Go buy a Honda filter from the dealer and check out how small it is. But I see you have two Honda's so you probably already know that.
Yes, my Ridgeline uses the same filter but it seems to have a somewhat smaller flange facing than the '04 Odyssey. It also has a 3.5 L engine but some of the details are different from the Ody's. It's amazing that an engine of that size uses such a small oil filter! It's a lot smaller than the one in my Saturn!
I see that Amsoil also calls out a Wix filter for this vehicle; maybe I'll get one of those and compare it.
The Odyssey may not use that small of a filter in all markets. It might be a US thing.
Here's all the filters in that thread that Donaldson carries. I tend to think that they're more global on the east Asian end of things ..but that could just be my imagination. Most fall into a 2.6x O.D. ..a few in the 3.xx ..and some bigger.
ty Item Number Item Description Attribute Description Attribute Value
P502007
LUBE SPIN-ON COMBINATION
A - OD (Inches) 2.68
B - Thread Size (Inches) M20 X 1.5
C - Length (Inches) 3.34
D - Gasket OD (Inches) 2.67
E - Gasket ID (Inches) 2.15
Relief Valve Setting (PSI) 11-17
Anti Drain Valve (Y/N) Yes
Product Type Description LUBE SPIN-ON FULL FLOW
Primary Application MITSUBISHI MD135737,
Primary Application 2 30A4000100
Product Group F
P502009
A - OD (Inches) 3.15
C - Length (Inches) 2.52
D - Gasket OD (Inches) 2.48
E - Gasket ID (Inches) 2.03
Primary Application MITSUBISHI MD136466
Product Group F
P502049
B - Thread Size (Inches) M20 x 1.5
C - Length (Inches) 3.15
D - Gasket OD (Inches) 2.49
E - Gasket ID (Inches) 2.00
Primary Application HONDA 15400-PR3-004
Product Group FL
P502051
C - Length (Inches) 3.94
E - Gasket ID (Inches) 1.81
Primary Application HONDA 15400-PH1-014,
Primary Application 2 15400-PK1-003
Product Group F
P502056
A - OD (Inches) 3.16
C - Length (Inches) 5.64
D - Gasket OD (Inches) 2.50
E - Gasket ID (Inches) 2.28
Primary Application MAZDA 145623802
Primary Application 2 145623802A ,RF0323802
Product Group FL
P502057
C - Length (Inches) 3.35
D (Inches) 2.56
E (Inches) 3.03
Primary Application MAZDA FEY014302
Product Group FH
P502062
C - Length (Inches) 2.56
D - Gasket OD (Inches) 2.58
E - Gasket ID (Inches) 2.17
Primary Application KIA
Product Group FL
P502063
Primary Application MAZDA JEY014302
Product Group F
P502067
D - Gasket OD (Inches) 2.56
E - Gasket ID (Inches) 2.19
Primary Application NISSAN, MAZDA, MITSUBISHI
Product Group F
P502092
A - OD (Inches) 3.52
C - Length (Inches) 3.23
D - Gasket OD (Inches) 2.44
E - Gasket ID (Inches) 1.98
Primary Application PROTON
Product Group FL
P550067
ELEMENT, LUBE SPIN-ON
A - OD (Inches) 4.2
C - Length (Inches) 4.98
D - Gasket OD (Inches) 3.9
E - Gasket ID (Inches) 3.46
Primary Application MITSUBISHI MEO14833
Product Group FL
P550158
LUBE SPIN ON
A - OD (Inches) 3.81
C - Length (Inches) 3.7
D - Gasket OD (Inches) 2.82
E - Gasket ID (Inches) 2.42
Relief Valve Setting (PSI) 8-11
Primary Application FORD E3TZ6731C
Product Group F
P551762
LUBE SPIN-ON
A - OD (Inches) 3.18
C - Length (Inches) 3.39
E - Gasket ID (Inches) 2.11
Primary Application Kubota 70000-15241
Product Group F
P550173
SPIN-ON LUBE FILTER
A - OD (Inches) 3.67
C - Length (Inches) 3.16
D - Gasket OD (Inches) 2.63
Relief Valve Setting (PSI) 8-10
Primary Application CHRYSLER
Product Group F
P550383
LUBE FILTER SPIN-ON
A - OD (Inches) 4.13
D - Gasket OD (Inches) 3.92
E - Gasket ID (Inches) 3.52
Primary Application ISUZU 8941145850
Product Group F
P550405
C - Length (Inches) 3.98
Primary Application HINO 2330478020
Product Group F
P550412
LUBE SPIN-ON BYPASS
A - OD (Inches) 3.64
C - Length (Inches) 4.92
D - Gasket OD (Inches) 3.43
Product Type Description LUBE SPIN-ON BYPASS
Primary Application MAZDA SL5014V61
Product Group F
P550718
LUBE FILTER
A - OD (Inches) 3.7
C - Length (Inches) 4.15
D - Gasket OD (Inches) 3.5
E - Gasket ID (Inches) 3.11
Primary Application ISUZU 8-9421-7272-0
Product Group F
P550726
LUBE FILTER
A - OD (Inches) 3.28
C - Length (Inches) 2.78
D - Gasket OD (Inches) 2.52
E - Gasket ID (Inches) 2.26
Relief Valve Setting (PSI) 11-15
Primary Application KUBOTA 15841-32430,
Primary Application 2 15841-32431
Product Group F
P550776
LUBE SPIN-ON
B - Thread Size (Inches) M20 X 1.5-6H
Anti Drain Valve (Y/N) 10-15 PSI
Primary Application KUBOTA 7000015241
Product Group FL
P551257
LUBE SPIN ON
A - OD (Inches) 4.24
C - Length (Inches) 6.52
D - Gasket OD (Inches) 3.95
E - Gasket ID (Inches) 3.6
Primary Application ISUZU X13201012
Product Group F
P551264
LUBE SPIN ON
C - Length (Inches) 5.62
D - Gasket OD (Inches) 3.94
E - Gasket ID (Inches) 3.56
Primary Application KOMATSU/KOMATSU DRESSER
Primary Application 2 Z1402OF105
Product Group F
P551306
LUBE SPIN ON
D - Gasket OD (Inches) 3.59
Relief Valve Setting (PSI) 13.50
Primary Application HONDA, ISUZU, MAZDA
Product Group FL
P551783
LUBE SPIN-ON
A - OD (Inches) 2.69
D - Gasket OD (Inches) 2.42
E - Gasket ID (Inches) 2.23
Primary Application HONDA 15410MM90003
Product Group F
P552381
A - OD (Inches) 3.670
B - Thread Size (Inches) 20 X 1.5 MM
C - Length (Inches) 3.141
D - Gasket OD (Inches) 3.444
E - Gasket ID (Inches) 3.100
Primary Application HONDA 15400-634-003
Product Group F
P552849
SPIN-ON LUBE FILTER
A - OD (Inches) 2.96
C - Length (Inches) 3.4
D - Gasket OD (Inches) 2.7
E - Gasket ID (Inches) 2.33
Relief Valve Setting (PSI) 11 - 17
Primary Application FORD, MAZDA
Product Group F
P555522
LUBE FILTER
A - OD (Inches) 3.12
C - Length (Inches) 3.87
D - Gasket OD (Inches) 2.45
Primary Application THERMOKING 11.5522, J.DEERE,
Primary Application 2 YANMAR
Product Group F
