I'm studying the lube schematic for my Volvo 41 diesel marine engine. According to this print, this engine uses pressure relief valves and controls (limits) oil pressure to the main galley and to the piston cooling oil galley at different pressures. Approx 70psi and 35psi.
The oil pump is always pumping way more oil than the engine can accept (allows full pressure at lower rpm) and is constantly dumping oil back to the pan before it gets to the filter.
With an Amsoil dual filter bypass setup, the effect is to reduce my actual engine oil pressure by the amount of the flow restrictor in the dual bypass filter setup. I understand this to be about 10 PSI.
In an engine which sends all pumped oil to the oil filter, the restrictor in the Amsoil bypass dual filter setup would have no affect on the pressure the engine sees. The pressure between the pump and the Amsoil block would simply increase a bit, but the engine would get the same flow, no harm done.
However, with a pressure regulated setup such as on this Volvo diesel, pressure to the filter block is regulated, the Amsoil block adds another spring restriction in the system, effectively reducing oil pressure to the engine and also reducing oil volume to the engine.
You can bet my Amsoil Dual filter block is coming off this engine! I will, however feel safe putting it on an engine which feeds oil directy to the filter without pressure regulation.
I certainly do not mean to dissuade anyone from using the Amsoil Dual bypass block on appropriate engines.
