Amsoil BMK21-Sandwich adapter
Long Island/New York
I have the Amsoil BMK single remote bypass filter and I was wondering if I could use a oil filter sandwich adapter with two ports,one for input and one for the return to the full flow oil filter.I dont want to tap into the oil cap or oil pan.Thanks Joe
On what? Passenger car engine? A Permacool sandwich? Sure.
You can probably dispense with the smaller hoses if you want to. If you don't, you'll need to get some NPT to JIC adapters ..or a JIC/AN to NPT depending on which end you want to change. The mounts have 3/4-16 threads O ring boss fittings.
To got to NPT, you need one of these on the Amsoil end(s)
If you're adapting from the Permacool end, you need these.
They still appear to be using the 3/4-16 thread filters. That means a standard Permacool
181 Sandwich Oil Adapter
Fits 3/4"-16 threads. Designed to fit most Fords, Chryslers and Dodges. 1" thick. 3/8" NPT(int) ports for use with 1/2" oil lines. 2-1/2" O-ring included.
If you're going with mostly Amsoil parts:
BP189
Adapter fitting, 3/4"-16 male straight thread with "O" ring to male 3/4" JIC BMK13, 14, 15Ea, 16Ea & 17Ea
(2) two
This is for the Permacool sandwich
BP190
Adapter fitting: 3/8" MNPT to 3/4"-16 JIC BMK13 & 14
(2) two
BP187
Hose fitting, 13/32" ID hose to 3/4"JIC female swivel BMK13, 14, 15Ea, 16Ea & 17Ea
(4) four
BP188
13/32" I.D. hose 8' length (discontinued) BMK14, 15Ea, 16Ea & 17Ea
USE
BP217 hose sold by the foot
If you want to go with hose clamps and something like trans cooler line (totally acceptable, imo) ..then you can use hose barbs.
This only complicates it since you need the ORB fittings.
You can get two of these from Amsoil for the mount and just remove the petcock. This (iirc) is a 1/8" thread
BK13
Oil sampling petcock valve BMK13, 14, 15Ea, 16Ea & 17Ea
you would then just buy hose barbs to fit the hose you decide on (let's say 5/16" trans cooler hose).
You would get 3/8 X 5/16 barbs and 1/8 X 5/16 barbs.
Enough length of 5/16 hose ..and four hose clamps ..you're done.
Gary,Thanks again for the help.I ordered the parts you mentioned I needed.I have a question for you.Besides the sandwich adapter parts why couldn't I use the hose(1/4 inch)and other parts that came with the kit?I see that 11/32 inch hose was called for.The reason I ask is because I would of used the wrong hose and other parts.again Thanks Joe
