amsoil ATM 10w30; 4 UOA; 2010 v6 explorer
pb
stl
2010 explorer, 4L v6, 4x4, purchased in oct 2011 w/ 35.7k miles. 60% highway driving.
Code:
OIL ATM 10W30 ATM 10W30 ATM 10W30 UNK
MILES IN USE 8.8k 9.1K 10.6K EST 5K
O&F CHANGED Y Y Y Y
MILES 65.7k 57K 47.8K 37.3K
MAKEUP OIL 0 1 0 0
SAMPLE TAKEN 11-JUN-13 20-NOV-12 10-MAY-12 17-NOV-11
LAB OAI OAI OAI OAI
IRON 15 13 18 8
CHROMIUM 1 0 1 0
NICKEL 0 0 2 0
ALUMINUM 6 6 7 5
COPPER 5 7 4 4
LEAD 0 0 1 0
TIN 1 0 0 0
CADMIUM 0 0 1 1
SILVER 0 0 0 0
VANADIUM 0 0 0 0
SILICON 19 19 16 7
SODIUM 9 8 7 5
POTASSIUM 0 6 0 0
TITANIUM 0 0 0 0
MOLYBDENUM 156 146 132 78
ANTIMONY 1 1 0 0
MANGANESE 0 0 0 0
LITHIUM 0 0 0 0
BORON 91 52 72 120
MAGNESIUM 14 17 24 22
CALCIUM 3417 3398 3266 2516
BARIUM 0 0 1 8
PHOSPHOROUS 620 653 644 733
ZINC 676 732 711 809
WATER 0 0 0 0
cSt @ 212ºF 11.1 11.1 10.7 8.8
FUEL 0 0 0 1.1
TBN 2.88 4.09 3.04 5.44
OXIDATION 57 40 49 16
NITRATION 17 13 16 21
why did you decrease your interval?
looks fantastic to me but an oil that expensive with only 8.8k? I think its too short of an OCI
You car seems to be fairly hard on the oil for even though TBN reduction is not linear, it started at 12.6 (Amsoil specifications) and in 8.8K it is down to 2.88. This would likely not make it to the 15K (severe service) and definitely not to the 25K (normal service) intervals that Amsoil suggests it would.
As compared to other OTC synthetics, AMSOIL Signature Series is more expensive and since it does not appear that you can get the full OC out of it, have you considered using a different version of Amsoil or a different brand of oil? Also, why 10w30 instead of 5w30?
Quote:
what is amsoil ATM?
search seems to show, Signature Series is ATM?
i call it by the product code. it was ATM long before it got the moniker SS
i simply changed it because of timing- good day, cleared garage, etc.
yes, i'm unwrapping my head from years of amsoil use and considering it. i'm getting there. i just do not want to create new headaches. this engine has a existing issue with timing chain noises (tsb 10-18-11).
from prior 5w30 use it burned off. the 10w30 subsides it.
Quote:
Does that engine specify a 20 grade.
manual says 5w30 (the v8 gets 5w20)
Originally Posted By: pb
yes, i'm unwrapping my head from years of amsoil use and considering it. i'm getting there. i just do not want to create new headaches. this engine has a existing issue with timing chain noises (tsb 10-18-11). From prior 5w30 use it burned off. the 10w30 subsides it.
If you like Amsoil, you could go for the XL series of oil which has a 10K OCI. The retail price is about $2.50 per QT cheaper (PC pricing could be more than that) saving you a little money versus SSO.
Dont use SSO, as this used to be the code for signature series 0w30 oil, which is now AZO.
Btw, what filter are you using?
their ea011
