Quote:
Quote:
Its been in my Mothers 1993 Chevy Lumina since about 1994 with less then 10,000 miles if I recall, 81,000 miles to date and still ticking. Had them drop the pan and change the filter about 75,000 miles last fall. It was not changed back in '94 because the trans shop said it was unnecessary. Pan was like new on the inside, put in a Wix filter and its good for the rest of its life.
btw - same shop in '94 and 2006 did the work, same tech also.
Mike: Are you saying that you ran Amsoil from 10K til 75K and then changed the fluid (to Amsoil again) or are you saying you re-installed the used Amsoil?
I changed my Buick Centurys original fluid to Mobil 1 at 36K and now have 86K. I don't know whether to go to 60K on this fluid or change it soon (before the cold weather). The M1 has performed flawlessly and still looks red and smells OK. I also added Lubegard Red approx. 20 or 25K ago. I would think that if regular ATF is good for 30K than synthetic should be good for 60K. What do you guys think?
I will use Amsoil ATF in my Accord but the M1 was easier to find when I was changing out the Buicks. The M1 is excellent in the GM 4T65E transmission.
