Amsoil ATF changed recently?
You may not know even when you get it. They have several warehouses and obviously containers of QTs, gallons and 2 1/2 gallons.
And they may use old label containers for new formula ATF.
That's not true. Follow the label.
Originally Posted By: The Critic
If I order Amsoil ATF now, will I be getting the "high viscosity" version from the warehouse? Does anyone know whether or not all of the old stock has been gone?
New high vis stuff. The LV and Portland DC's will only ship the new juice with the new labels into CA.
Originally Posted By: katsdad
So will there be 2 universal products now?
Well, that's not exactly the wording I would use, the Amsoil ATF line-up will be (in about June):
ATF - upper end viscosity ATF for Dex III, Z-1, Mercon, T-IV, etc
ATL - lower end viscosity ATF for Dex VI, WS, etc
ATD - Allison® TES-295 or C4, DEXRON® III, MERCON®, Voith G-1363, ZF® TE-ML 14C
ART - Racing ATF, Type F, C-4
CTG - Powershift Transmission Fluid SAE 10W
CTJ - Powershift Transmission Fluid SAE 30W
CTL - Powershift Transmission Fluid SAE 50W
So the new ATF will be "thinned" a bit. Have been using it in my 2005 V6 Accord.
By "it" you mean earlier formula ATF. (neither the new ATL or the newly reformulated ATF)
Originally Posted By: tuckman
Pablo
Are any of these going to with the Ford FNR5 fluid/Mazda M5 ATF?
Wondering the same thing...maybe the new version?
Originally Posted By: BTLew81
Thanks..anxiously awaiting the answer!
I have posted this question on other forums also with no updates from other amsoil reps. Looks to me like they don't know yet either.
I guess if we bump this every couple weeks it should keep the question fresh
