Note 1)
Plugs and air filter were changed by dealer prior to this run @ 40k service
Note 2)
Five ounces of LC20 added 500 miles prior to taking this sample, to check effect on viscosity. I believe OAI has re-calibrated their FTIR machine recently, which may account for the seemingly high, Ox/Nit readings?
Oil Used------------AFL/ATM/AMO
Miles on sample---9600/9500/5500
Oil added---------0.75/0.75/0.5 qts
OEM Air/Oil filters
EOT Viscosity(Cst)-----13.75/11.35/12.5
Nitration---------25.0/7.0/1.0
Oxidation---------58.0/10.0/3.0
TBN---------------5.1/5.4/8.1
Water--------------0/0/0
Fuel---------------< 1%/< 1%/< 1%
Wear Metals: 5w-40/10w-30/10w-40
Fe, 17/9/8
Cr, 1/1/1
Pb, 1/2/2
Cu, 10/13/9
Sn, 0/0/0
Al, 5/2/2
Ni, 0/0/0
Si, 13/9/6****
Oil Additives:
Boron, 6/25/3
Na, 6/5/4
Mg, 177/701/67
Ca, 3549/2204/3068
P, 1279/908/997
Zn, 1380/1220/1193
Moly, 2/3/7
All in all, about what I expected...you can see the direct effect of dirt levels on upper engine wear. Additive package looks like a CI-4+/SL, HD diesel oil and even with the five ounces of 10wt LC20 added just prior to testing, viscosity did not drop much from 14.5 Cst baseline.
Am now using 0w-40/AFF and will do an early check @ 3k miles to evaluate Oxidation/Nitration levels.
TS
Note 2)
OEM Air/Oil filters
Fe, 17/9/8
Cr, 1/1/1
Pb, 1/2/2
Cu, 10/13/9
Sn, 0/0/0
Al, 5/2/2
Ni, 0/0/0
Si, 13/9/6****
Oil Additives:
Boron, 6/25/3
Na, 6/5/4
Mg, 177/701/67
Ca, 3549/2204/3068
P, 1279/908/997
Zn, 1380/1220/1193
Moly, 2/3/7
TS
