Originally Posted By: raffy
Originally Posted By: HighViscosity
Instead of wasting money on premium oil and uoa's for a rarely used car, why not just use a cheap "good" oil, change it once a year and spend the difference on something you can enjoy.
At 2500 miles, I'd think you might be impressed with the ad-pack of any approved oil.
That actually did cross my mind. I do have a pretty good stock of Amsoil 5W-30, so if I don't mind changing it once a year even though it costs more. The only other vehicles I have that use 5W-30 are lawn and garden equipment. Once I run this stock out, I may switch to something like PP (or whatever synthetic is on sale and/or has a rebate at the time).
I will probably slice open the next EaO filter I change. Those insolubles bother me a bit. They may be from Amsoil cleaning stuff out of the engine but I've been using it in this car for about 25,000 miles. Maybe these Saturn engines just run dirty!
These cars do "run dirty". Take a look at your throttle body some time after 10-15,000 miles.
Do yourself a huge favor as I have tried everything on my SL.
1. Purchase a case of Redline SI-1
2. Run one shock treatment of 1 entire bottle per a quarter to a half a tank
3. Change oil and from then on run 1 ounce per 10 gallons (you'll get a ton of use from one bottle once on a maintenance dose)
The high levels of PEA in the SI-1 really do work in this carbon monster of a car. My throttle body plate shows 10% of the carbon it used to when not running SI-1. I will take a picture next time I remove and clean the throttle body area.
Also, I keep track of fuel economy in this SL and I have increased my fuel economy to 1-1.5 mpg over the past 8 months or so since using the product.
I do not ever endorse a certain product on here over another, but this SI-1 stuff works even better than Techron and Regane and those are great products.
Also, if you PCV isn't an OEM one that says:
AC Delco CV 947 C 12, throw it away and get some. They do get really dirty in these cars.
They cost 3.62 a piece and I ordered a half a dozen (shipped to my house for only a couple bucks from Saturn of Brooklyn Park in MN).
NOTE: If you already know all of this, disregard.
