This is a fill of 4.5 quarts Amsoil ASM 0W20 that I put in November 1, 2008 with a Mobil 1 filter (believe M-103 but will check the number on the filter again). Air filter was stock filter, replaced this OCI with a wix filter.
I still have the oil filter if anyone wants it cut open.
Ran 1 year. Probably 90% of it was severe service, 1.5 mile drive to work, sit for an hour then drive on to the base under a mile and sit until lunch time, then drive back to the office for an hour, then back to the base until 5 then drive home.
Would go to Warwick which is about 23 miles one way and drive around town then head back at the end of the day. Whenever the misses would want to go to the mall or Dave & Buster's I insisted we take my car so I could get it on the highway at 65-70mph for a good 45 minutes each way.
I refilled with Chevron Supreme 5W20 and a Pure One 14477 filter. I still have 18 quarts of ASM left so I dont know why I did not refill with the same. Just want to get rid of some of the oil I have on hand maybe. I think I will dump the Chevron after 6 months and go back to ASM.
ALUMINUM -4
CHROMIUM -1
IRON -11
COPPER -4
LEAD-0
TIN-1
MOLYBDENUM-3
NICKEL-0
MANGANESE-6
SILVER-0
TITANIUM-0
POTASSIUM-1
BORON-8
SILICON-18
SODIUM-8
CALCIUM-2380
MAGNESIUM-39
PHOSPHORUS-633
ZINC-667
BARIUM-1
cSt Viscosity @ 100°C 8.26 (should be 6.0-10.2)
SUS Viscosity @ 210°F 53.3 (should be 46-59)
Flashpoint in °F 530
Fuel % Antifreeze % 0.0
Water % 0.0
Insolubles % 0.3
TBN 2.5
I will post up the other uoa's to see the trends later.
Blackstone's comments:
Michael: Thanks for the note about the oil filter being in place for so long. We measure the effectiveness of an oil filter with the insolubles test. They were low at 0.3%, which shows that the oil filter did a good job even after being in place for so long. Copper improved yet again and now reads close enough to average levels to be considered normal. Wear looks great here and shows no obvious problems developing. You still had some active additive left in this fill with a TBN reading of 2.5. 1.0 is too low for extended use. Everything looks good. Nice improvement!
ALUMINUM -4
CHROMIUM -1
IRON -11
COPPER -4
LEAD-0
TIN-1
MOLYBDENUM-3
NICKEL-0
MANGANESE-6
SILVER-0
TITANIUM-0
POTASSIUM-1
BORON-8
SILICON-18
SODIUM-8
CALCIUM-2380
MAGNESIUM-39
PHOSPHORUS-633
ZINC-667
BARIUM-1
Water % 0.0
Insolubles % 0.3
TBN 2.5
