Amonia works for a stubborn kitchen drain!
OH
I'd been playing around with the drain in the kitchen sink since Tuesday.
I left work early yesterday thinking of doing a few errands and then snaking out the kitchen drain, which was clogged to the point that running the dishwasher was out of the question.
I played around with the snake for an hour or so and simply could not get past a certain point, probably where the clog lay.
I was looking at buying a heavier duty mechanical tool, and then I remembered one of those old wives' tale things my mother had once sent me.
The tale was that you could pour ammonia down the drain and let it sit for about twenty minutes and then flush the drain with boiling water.
I figured that for the buck and a half Kroger wanted for a half gallon of store-brand ammonia, I had nothing to lose.
To my great surprise, this worked perfectly.
The drain is now running better than it has in years.
This was not only the easy way, but it also turned out to be the right way.
Just a little helpful advice on resolving grease clogs based upon my happy experience.
I had one in my 2nd story bathroom sink drain that i fought for a MONTH-after buying & trying 3 augers including a 50 footer, I bought one of those Drain King tools that run off a garden hose, it built up pressure & blew the clog out so fast it flushed the toilet attached to the same stack!
I have a similar device and it does work well.
I'm reluctant to use it on a drain with multiple slip joints, though.
Too much potential for blowing a joint apart rather than the clog.
Still, it did work for you when nothing else did.
Yep...I posted this combination in another thread. Ammonia is alkaline and will disassemble protein & fat, given time. Boiling water (or even just really hot ~ 160°F) will dissolve gunk/backups much better than cold water.
TSP (also alkaline) also works well followed by HOT water. Lye or sodium hydroxide, is even MORE alkaline and commonly used as both drain & oven cleaner. Does a great job at dissolving fats & protein due to its strong alkalinity.
Ammonia is safer for septic systems as well.
Ammonia and hot water is great for tile floor and grout cleaning. It's all I use for those.
