Scott S
Thread starter
I have no idea to have the same license number? I would have to look I guess when I go to Walmart.Do they have the same DEXOS license number ? If they do, they are the exact same oil inside the bottle.
Well actually you are saying that. What makes one additive package more stout than another? What's your basis for this qualitative decision?No I'm not saying that.. I meant, which one has a stouter additive package
OpinionWell actually you are saying that. What makes one additive package more stout than another? What's your basis for this qualitative decision?
I'm just really curious if, one oil is different than another. Or are they all the same oils with different labels? Me personally for the, for the cost I would just rather go with the name brand. Because you're not saving that much anymore..Well actually you are saying that. What makes one additive package more stout than another? What's your basis for this qualitative decision?
ApprovalsI'm just really curious if, one oil is different than another. Or are they all the same oils with different labels? Me personally for the, for the cost I would just rather go with the name brand. Because you're not saving that much anymore..
Let me ask you a question? If you're not suppose to go by the additive package of the oil and the base oil, what exactly are you supposed to go by? If you don't mind me asking?
Well Supertech as approvals so does Castrol edge and Mobil 1 do they both compare?Approvals
All of them are high-quality oils that will not contribute to oil-related engine damage or failure.Well Supertech as approvals so does Castrol edge and Mobil 1 do they both compare?
Definitely not, but one I'm sure has higher detergency, to lubricate the engine better and to keep it cleaner.. and that would be the stouter oil I would guess..All of them are high-quality oils that will not contribute to oil-related engine damage or failure.
There are oils that are "stouter" meaning that they have approvals that are more demanding. Like Euro oils that are based off of ACECA A3/B4 and ACECA C3Definitely not, but one I'm sure has higher detergency, to lubricate the engine better and to keep it cleaner.. and that would be the stouter oil I would guess..
I am not ranking them in any order but if you think you can determine which is "better", good luck !Definitely not, but one I'm sure has higher detergency, to lubricate the engine better and to keep it cleaner.. and that would be the stouter oil I would guess..
What I'm saying, if you compare super tech to Valvoline, Valvoline has a lot more Molly.. that's what I mean by stouterThere are oils that are "stouter" meaning that they have approvals that are more demanding. Like Euro oils that are based off of ACECA A3/B4 and ACECA C3
Let me ask you this question, what oil do you use and why?I am not ranking them in any order but if you think you can determine which is "better", good luck !
