Has anyone done a VOA on this oil yet? I just want to compare it to Kirkland synthetic?
I don't think they are exactly the same..I thought they were the same?
Both made by Warren. Same oil different label.I don't think they are exactly the same..
What do you mean different level?Both made by Warren. Same oil different level.
Label. Not level. AutocorrectWhat do you mean different level?
That's what I'm figuring, I would like to know which one is the better one, if there is a better one..Probably 1 oil is better than the other, meaning maybe a more robust additive package. In other words, it would be like Coca Cola versus your supermarket brand cola. 1 is more expensive and tastes better.
That makes sense.. LOLLabel. Not level. Autocorrect
Not even on Warren's website.. I just looked..🤷🏻♂️Instead of a VOA, maybe look at the SDS of both oils, meaning the Safety Data Sheets. What is nice about the SDS Sheets is that you have to be well honest. There was once a certain 2 stroke oil I was looking at and they claimed that it was Full Synthetic, but the SDS showed that it was really Mineral Oil.
That might be on their website I'm not sure..
It's extremely likely that they come out of the same tub.That's what I'm figuring, I would like to know which one is the better one, if there is a better one..
I picked up Kirkland several months back, I figured I'd try synthetic for the first time in this vehicle.. it's doing well.. so I'm thinking about going with Castrol Edge or Quaker State cause for the price it is pretty stout oil..I do not want to tell you what oil to use, but I will only use an oil where I can look at a SDS.
An SDS is not an ingredient list. Don't put too much value into what it lists as it's certainly not the whole picture.maybe look at the SDS of both oils
So you're saying that if two oils have the same approvals, licenses or certifications you can determine which one is better through a $30 spectrographic analysis? Or the typical values listed in a PDS?That's what I'm figuring, I would like to know which one is the better one, if there is a better one..
I will look at an SDS over an oil companies advertisement about there oil. In a sense from what I have seen with SDS's on oils it does give some clues to the ingredients, meaning if the oil is synthetic or mineral.An SDS is not an ingredient list. Don't put too much value into what it lists as it's certainly not the whole picture.
No I'm not saying that.. I meant, which one has a stouter additive packageSo you're saying that if two oils have the same approvals, licenses or certifications you can determine which one is better through a $30 spectrographic analysis? Or the typical values listed in a PDS?
Do they have the same DEXOS license number ? If they do, they are the exact same oil inside the bottle.Both made by Warren. Same oil different label.
