Originally Posted By: Finz
I've read that 3 drain/refills over a fairly short number of miles... 20k maybe... Supposed to ensure a near-complete fluid change... I didn't go that route myself
The washers from honda are a ridiculous price at the dealer... Over $3 each I think
I think I'm paying about $9 or $10 for Honda's ATF. You?
Be interesting to see if your second drain shows as much of the filings on the plug as this first one
ATF change special at a dealer fairly close to where I work in Silicon Valley.
http://www.southbayhonda.com/honda-maintenance-parts-atf-change-kit-dealer-9258-sid-35634.html
$28.88 and tax for 4 quarts of DW-1 and a crush washer. Supposedly a coupon special, but I still get it if I point to the display on the counter showing the coupon. The receipt parts out the prices at $2.56 ($3.29 list) for the washer and $6.58 ($8.23 list) for each quart of DW-1. I'm not sure what happens if it's a car that uses the much cheaper M14 washer like pre-1990 Civics and Accords. My '89 Integra used the same washers as the oil drain plug for the ATF drain bolt. The last time the part guy automatically whipped out an M18 bagged single. The first time another guy asked me what model.
I found a local shop with loose washers in a plastic assortment box. They wanted 91 cents for M18 copper washers and I bought three. Probably don't need all of them, but they're cheap and nice to have. I even remember when I no longer had my Integra but had a bag of Honda oil drain plug crush washers. Had no real need for them until I married someone who had a Honda. Might have also worked if she had a Mazda.
Oh - have you replaced the power steering fluid? Not sure where the location would be on an Accord, but it's really easy on any Honda/Acura to do a service manual style purge. All it takes is pliers to remove the return hose, 1/2" O.D. tubing as an extension jammed into the return hose to collect the fluid, a 1 quart bottle (empty motor oil bottle works fine), and maybe 2 (3 to be sure) 12 oz bottles of Honda Power Steering Fluid. The one thing that I would recommend is that you have an assistant hold the collection container and whatever extension tube. That makes one less thing that could go wrong - i.e. the tube possibly shooting out of the container and spraying PSF on any belts. My wife's Civic had a nasty power steering pump whine, which went away with a little addition of Honda Power Steering Fluid to the max line. Turning effort was much easier after the complete purge. And some claim that air in the system will make things worse, but I've found that air is quickly purged from the system.
