Yep. You attach the funnel and pour in coolant until it starts to rise in the reservoir. Start the car, turn heat on high (with or without heater fan) and let it run at idle. As the system gets hot and the thermostat opens, coolant will flow into the reservoir from the funnel and air will be purged. Eventually it will stop filling at the correct level in the reservoir and the system should have purged itself of any air while it was running, usually after the cooling fans have come on a few times. Insert the stopper in the funnel if you still have coolant in it and transfer the excess back to the jug. Done.
