There's this question I've kept asking myself since joining BITOG, and I still haven't found a definitive answer...
Is it better to always use the same oil? I've read that additive bond to metals with pressure and heat during oil use, that new oil is more aggressive and first start to dissolve part of the previous additive layers before rebuilding new layers of additives, etc...
When I'm buying oil, it's usually because it's on sale, so I usually don't use the same oil twice (or for example I use oil A one, then oil B, then oil A again).
Will it be better to always keep the same oil throughout the life of an engine (if it's reasonably possible, of course, manufacturers change formula)? So the layer of additive stays undisturbed (less disturbed) and there's no "additive clash" between brands of oil? Or is this a myth?
For example at the moment I have Motul 300V in my car, next OC will be Shell 0W40 because I have some, and in the future I want to try Valvoline Maxlife 5W40. Should I reconsider and stay for example with 300V (since it appears to do well), instead of using whatever I have on hand / is on sale at the moment of the OC?
Tell me if I'm wrong, and if my engine will ever notice the difference
