winter has been sucky.We are about done with FLOOD-FREEZE-SNOW-FLOOD-FREEZE-SNOW-WIND-FLOOD-FREEZE-SNOW-SUPER WINDY!!
This is my local range (new to me) I joined last summer. Can't wait until 55+ °F days!!
https://www.custersportsmensclub.com/
Are you talking about copper clad steel projectiles only? The copper cladding is super thin, so I'd think as the bullet travels down the barrel the rifling my cut down through the copper cladding and gets into the steel.In most pistol barrels the increased wear potential of steel in the projectile is something only very high volume shooters may see.
Where it does present a real issue of wear, is a rifle barrel. Not steel cased but steel in the projectile has shown to wear out an AR barrel sooner than non-steel.
But if the steel bullet has a decent copper casing, then I would think there would be no rifling cutting down deep enough to get into the steel core of the bullet.
There were some issues early on with misfires in the Ruger Mini 14's in 7.62 X 39 MM, with some steel cased Russian ammo. This was due to the Russian ammunition having harder primers than the commercially produced brass stuff in this country. The original 7.62 X 39 MM Mini's had a somewhat weak firing pin spring, that would produce misfires with some brands. This added to the problem.
I ran into a guy shooting one at the range several years back, with some steel cased Russian stuff in a Mini. And he had well over 2 dozen rounds sitting on the bench, out of over a hundred rounds that he ran through the gun that didn't fire. You could see the primer indentations were very shallow. I put them into my Yugo underfolder, and they all ran fine.
I gave him mag full, (30 rounds), of the Golden Tiger 7.62 X 39 MM I was shooting, and every one went bang in his gun. So I swapped him 100 rounds of my stuff for his, and he had no more issues.
I read where Ruger has since fixed the problem. I'm assuming they installed a stronger firing pin spring. As most everyone with a 7.62 X 39 rifle is going to shoot steel cased ammo of some type in them.
Yes. I should have made that clear. My mistake. And it was only with a few of the early production rifles. Ruger Mini's today will fire most anything dependably.......Are you meaning the hammer spring?
My Mini-14 has shot thousands of rounds of Wolf type ammo with no failures. I did get some FTEs with Federal AR223 which I attributed to being really weak sauce.
I also shoot a lot .Nope. The reloading thing is the biggest reason. I've shot thousands of rounds of steel cased ammo and the only issue I've ever had is it seems to be a little dirtier if you get the Russian brands like Tula/Wolf.
I agree, Wolf, Tula, poly coated steel cased 9mm appears to be good stuff. The only steel cased stuff I have ever had problems with was old Brown Bear lacquer coated 9mm ammo, but that stuff is no longer made IIRC.I also shoot a lot .
I believe Tula in 9mm is actually pretty good ammo.
reasonably accurate.
Not loaded hot , but not too light either as some 9mm economy rounds are.
Goes bang everytime.
