That's because the range wants to collect the brass and sell it.When I was living in FL, some of the indoor ranges would not allow it...brass only.
yupThat's because the range wants to collect the brass and sell it.
I've heard the arguments that steel cased ammo damages the backstops, manure.
To be fair, he asked about the down sides of aluminum and steel cased ammo.This thread keeps drifting from steel cased to steel projectiles . The original post was about steel and aluminum CASED ammo .
Can you cite a manufacturer and product? I'm absolutely no expert, but none of the 7.62x39, .380ACP, or 9mm Parabellum with steel cases that I've shot have had steel (or steel coated) projectiles AFAIK.Most steel cased ammo also comes with steel coated projectiles.
These all look to to have copper jacket or coated bullets. This link shows steel case with steel phosphate polymer coated bullets.Almost ALL steel cased ammo is also loaded with steel coated projectiles. This is common knowledge. The projectile might then be coated with a brass or copper coating, but it’s still steel clad bullets loaded in steel cases. Wolf, Tula, Barnaul, most of the others are all loaded this way.
I would hazard a guess that you were probably mistaken and the 7.62x39, .380, and 9mm steel cased ammo you shot before was most likely loaded with steel clad projectiles.
3) Aluminum cases? Been on the market for decades. The only problem is in the minds of someone who hasn't used it. It's OK, we understand it's only been common in the lower tier plinking ammo since before you were born.
I haven't fired factory ammo in any of my personal weapons since the 1980s.I've used it and for me the big problem is that it's not reloadable...even if you bother to remove the Berdan primers that most of it has and can manage to find correct replacements, or find some of the rare boxer primed aluminum cased, you still run into the fact that aluminum doesn't handle being worked and resized the way brass does. The one time I reloaded a dozen boxer primed aluminum 38 specials, every single one split on firing.
By contrast, I have brass 38 Special cases that have been reloaded so many times that the nickel plating is worn off of them. They just keep going. Even high pressure straight walled brass are good for an easy 5 loadings.
If you don't reload, sure it may not matter to you. For those of us who do, even paying 30% more for ammo in reloadable cases is worthwhile, and the last time I priced Blazer or Herters aluminum the cost difference was less than that.
Tula Ammo 223 Rem 55 gr FMJ Steel Case 40/Box
Tula Ammo: 223 Rem 55 gr FMJ Steel Case 40/Box for sale at Sportsman's Outdoor Superstore.www.sportsmansoutdoorsuperstore.com
Did you mean lead on the receiving end?The Wolf and Tula contain steel in the projectile. There are not many range systems out there that steel is really an issue. Outdoor ranges shooting berm type arrangements don't like steel as many of them pick up spent brass and sell it as 1x used. But there are some systems out there that steel is a detriment. And so is copper to those systems.
Or are we talking about spent brass casings?
This is where confusion kicks in,
You mixed the two in the same sentence with no break. - but I knew what you meant......I certainly can be confusing!!
2 Seperate matters. 1 is the steel in the projectile and the other is steel/AL case. I have tangled the 2 in not such a gracious way. Sorry. In this instance, most outdoor ranges have some type of earth berm. Steel no issue. If the berm is made of rubber compounds, manufacturers state no steel, even alloys and no copper. My info is dated as this was years ago when my police department was looking into replacing our old baffle system with a rubber system.
The comment on outdoor ranges is directed at the casings. Recycling brass of a busy range for some ranges has become built in revenue. Kinda like your local town, city, or state has massive $$ built in the budget assuming LE will meet a line item amount of ticket revenue.
An additional matter is lead recycling. There are companies out there that go to ranges and clean them for a moderate price. Moderate price is often associated with the company removing all the lead and recycling it. The company I dealt with had a sweetheart deal with China. All they had to do was take spent lead and secure it in a type of vacuum sealed container and ship it. They did not have to do anything further. An issue for these cleaning companies is steel. It wreaks havoc with their profits as the recycler penalizes for steel in the lead mix.
This is how it was explained to me by the owner of the company we used for years to clean our indoor range.
Your info does sound a little dated but subject to local and experience. It's interesting to me. My more recent experience.
First of all. I like a covered outdoor range that has no controls on ammo type, short of incendiaries during dry season. This basically means:
1) Projectiles of any type - copper, lead, alloys, steel, copper washed, etc
2) Casings of any type, you can keep your casings if you like but clean up when complete (or whenever before done), sweep and pickup and put in mixed drum.
Of course there are variants on this, but you get the drift.
Bullets:
I have been a member of indoor ranges that allow no steel case, no steel projectile of any type, subject to magnet inspection - and I was innocently caught once. Brass cases, lead core projectile - in thin iron plating with a copper wash! Magnet stuck. They got real pissy with me and honestly I was ignorant. I had other ammo with me, but had to take mine to the car. They were concerned about backstop dividers and such, but the whatever side of me wonders how/why these 9mm bullets would be more damaging than say .44Mag pure lead alloy, full boat load, if you follow my logic.
And variants of the above..........
Cases:
Some are brass only as mentioned, and no picking up allowed at all (yikes)
Some are brass and steel, but steel in trash and brass in the brass can
We are about done with FLOOD-FREEZE-SNOW-FLOOD-FREEZE-SNOW-WIND-FLOOD-FREEZE-SNOW-SUPER WINDY!!Spring is coming here in NY. Still in teens overnight but those 65/75F days are near. On weekdays there is often nobody there. It is so much fun to be there in the trap field (full sun), alone, just you and the crazy orange disks of frustration! Sun beating down on you, beautiful clouds in a blue sky.
BISCUT ain't edgeumucated like most of us.You mixed the two in the same sentence with no break. - but I knew what you meant......
Bullets:
Cases:
