Me too. I've used steel 5.56 ammo with zero failures. I've used tons of aluminum cased pistol rounds also with zero failures.Nope. The reloading thing is the biggest reason. I've shot thousands of rounds of steel cased ammo and the only issue I've ever had is it seems to be a little dirtier if you get the Russian brands like Tula/Wolf.
The ranges collect and sell the brass. Big profit item. Aluminum and steel cases have little or no value and have to be sorted out.Biggest drawback I have expierienced is at a range that collects and sells their empty cases to a reloader. Steel and Aluminum cases are not allowed to be used. There could be another reason, like liability too, since they don't want you using reloads either.
You can bring your own ammo, but they like to check it. It also just so happens that they sell ammo as well, so who knows the real reason.
I haven't seen any modern steel cased ammo that is corrosive .It’s can be dirty and corrosive. Russian stuff mostly. The primers have potassium chlorate or sodium perchlorate which turns into potassium chloride or sodium chloride when fired. Salt basically. You just got to clean the gun afterwords. Other than that it’s good to go.
Modern, no. Wolf or something similar are non corrosive. But the old spam can stuff, not so much.I haven't seen any modern steel cased ammo that is corrosive .
I disagree. it’s military brass surplus that has corrosive primers. Wolf, Tula and Red Army Standard are not corrosive.It’s can be dirty and corrosive. Russian stuff mostly. The primers have potassium chlorate or sodium perchlorate which turns into potassium chloride or sodium chloride when fired. Salt basically. You just got to clean the gun afterwords. Other than that it’s good to go.
I have a uncle Sam also that fella has gone off his rocker , fruit loops . Might be we are related somehow ?i have shot non-brass ammo out of ruger blackhawk (45acp & 38sp) and taurus revolvers (38sp), and a makarov semiauto pistol (380acp), without any hiccups. i clean my firearms after use because my uncle sam told me to do so long ago.
I doubt people shoot guns enough to wear them out unless you are a gamer.The steel can be harder on ejectors, and both steel and aluminum have different pressure/expansion characteristics of the case. I forget where I read it, I think it was about use in revolvers, where there was a potential for an issue.
I run steel case rifle rounds sometimes, but I buy the ones with a proper FMJ bullet, not copper washcoat over steel. I also run synthetic coated bullets in handguns where I can. I personally wouldnt run the magnetic projectiles unless I was shooting a gun with a low cost aftermarket barrel. Id prefer to keep my stuff OE, and I think there is enough evidence that the magnetic projectiles will in time affect the barrel. YMMV.
The lucky gunner test showed significant accuracy decreases around 4-5k rounds with steel ammo. It was compellingly worse than standard FMJ.I doubt people shoot guns enough to wear them out unless you are a gamer.
