Alternator Replacement?
Originally Posted By: Vikas
Honda/Denso put diodes in the center neutral too.
I definitely "want" an oscilloscope! What kind of wallet damage are we talking here? HFT still does not sell one :-)
you can get handheld LCD scopes for not a lot of money. PartExpress used to have one... velleman IIRC, for ~$200. We use handheld ExTech models here for around $400.
if it's under 20khz there is freeware out there that will allow you to use the audio port (in) on a laptop... you have to build your own probes.
handheld lcd decent for most general use unless you start building advanced stuff.
and yes, the tube-fired heathkit o-scope that I had in my garage always got a lot of comments. i bought it at a hamfest for $20 years ago. Really enjoyed having it when working out small analog circuits!
Can you guys ascertain that the tensioner is at the end of the travel or at the beginning of travel?
Here is how it should be
Thanks!
