alternative to pennzoil synchromesh?
RI
I wouldn't jump from ATF to 90wt gear oil.
I'd try the Redline MTL.
Another option is to use a high mileage ATF, like Pennzoil or Valvoline.
Or, top off your transmission with up to a quart of 'snot' like Lucas.
The best way to fix a leak is to replace the gasket or reseal whatever is leaking!
Where is it leaking from?
its leaking from the rear seal
theres a lot of bimmer owners using mt90 to handle lightweight flywheel noises and its fine. companies reccomend it aswell.
i used mtl for about a year, it was great and leaked less, hence the mt90 i'm thinking right now
if theres a way to reseal without dropping the transmission... i'm there
i've had a leak from my transmission recently and i really dont want to drop it anytime soon. i've used auto rx but that didnt seem to help. as a matter of fact the leaking got worse after i switched to the synchromesh and treated it with a-rx.
so now i'm looking for a higher weight oil that may help some. so far the Redline MT-90 seems like a good alternative. thoughts?
the transmission is a bmw ZF 5 speed with an orange label calling for ATF only.
