Alternative to Fram PH8170 filter for a Briggs?
Texas
Are there any alternatives you would recommend to a Fram PH8170 or Briggs and Stratton 492932 oil filter for a 25 hp V-twin Briggs and Stratton engine? At ~ $12-15 it looks as if these filters are relatively expensive because they are so short and have few applications. It looks like I can fit a 1-1.5" longer filter. Does anyone have a list of cross references for slightly longer filters?
Originally Posted By: Throckmorton
Are there any alternatives you would recommend to a Fram PH8170 ... It looks like I can fit a 1-1.5" longer filter.
Try a PH3614. It's about 3/4" longer.
Super Tech (a.k.a Napa Select) ST3614 will run about $3
Why go for a longer filter of inferior construction? The PH8170 is very well built: metal end caps and all.
How much filter volume does a little Briggs honestly need?
Replacement oil filters for Fram PH8170:
Baldwin
B7165
Beck/Arnley
041-0767
041-8078
Bosch
0986452058
CARQUEST
85065
Champ
LF503
CROSLAND
2099
CUB CADET
120-5008
Donaldson
P502024
HASTINGS
LF503
John Deere
AM125424
AM125424C
AM131948
GY20577
KAWASAKI
49065-7007
LISTER-PETTER
751-12870
LUBER-FINER
PH3656
NAPA
1056
1056MP
7035
Tecumseh
36563
36961
740057
Wix
51056
57035
I made a list years ago using Purolator numbers:
Stock size (X-Small) - L35310
Small - L10241
Medium - L20195
Large - L30001
X-Large - L40017
I typically run the L10241 (uses 2 quarts right on the nose). Convert to any filter manufacturer you prefer.
Originally Posted By: BrianF
Fram 3614 fits great in my Craftsman T3200. The top of the line Ultra is still cheaper than the 8170.
That's what I was thinking. I can probably get a toughguard TG3614 for less than the cost of a PH8170. I'm pretty certain the toughguard is a better filter too.
I have the toughguard on as we speak. Even with the terrible regular Canadian prices, it was much cheaper and according to the filter dissections on this site they are a well built filter that, in my mind will have no issues running stock or longer changes.
I have yet to see a toughguard or Ultra with torn media or in general garbage construction. I will run the TG for the 100 hour index and rip it open to have a look.
The Fram 3600 or Purolator 20195 may fit,
same base as the 3614, but nearly five inches long,
The 3614 is three and a half inches long,
It also holds eight more ounces of oil, the 3614 holds four more...
I run the AutoZone STP blue S3600 on my Craftsman LT200 lawn tractor,
It does NOT need a bigger filter. He explained his purpose very clearly:
I think a $3 super tech will be just fine, I've been running ST3614's on big Briggs, Onan and Kohler engines for years and years and years ......
After hours of screwing around trying to save $6 I went to Home Depot and bought a nice heavy well made, B&S filter for my 20HP TWIN. I sleep well and will change it at ~ the 50 hours as recommended. You can op for a long life B&S filter, but, it is much more expensive. Ed
The PH8170 is a $6 filter.
Originally Posted By: tig1
I use the MC FL910S on my Briggs 21HP riding mower.
+1 mine is on a zero turn with the 21HP Briggs single cylinder
