30 WT Oil for everything!
Michigan
Well the manufacturers tell you to use some form of 30 wt in everything....
-A 3.5 Briggs gets a "30Wt Something".
-A 6.75 Hp Briggs gets a "30WT something".
-A V-twin from 14 HP to 25 HP gets a "30 WT something".
-A big single piston engine gets a "30Wt something".
-Hondas/Briggs/Kawasaki's/Robin/Dhaitsu/Techumseh...the same.
Whether it's hot...cold...extreme service..residential...commercial...one oil viscosity fits all....filter or no filter...I think NOT!
The reason I am going on like this is that my 20 HP Briggs V-Twin is shearing even a synthetic 10w30 to a 20 wt in a few hours (I do the used oil analysis...do the manufacturer's ....probably not..) and many of these engines fail due to bearing failure or piston scuffing issues. I am starting to think a stout Motorcycle oil like Amsoil MCF 10w30 or Mobil 1 4T 10W-40 is needed in my case. I used Mobil 1 15w50 for 15 years....yes after 50 hrs it was sheared to a 30 wt....but that's okay... and 1500 hrs with no problems on my 16 HP Briggs V-Twin... Before going to Motul 20W-50 (too much viscosity) and a non OEM filter (too restrictive) ...then engine failure...so there is a point where oil can be too viscous. But I am thinking a 5W-40 or 10W-40 synthetic is fine...Mobil 1 15w50 as well.
Like V-twin motorcycles...the shearing forces of a 20 HP V-Twin Briggs is just way too much for many oils...too much heat and too much shear.
My .02
True. All I can figure is; The manufacturers base their spec on 30wt's being the most readily available and it offers adequate protection over a wide range of conditions. The best protection and engine life? I doubt it. They make money selling engines.
Joel
I always thought those engines called for 30W because in the 'day' people used straight 30W for cars as a standard oil, and was the easiest to get because everyplace had it.
Originally Posted By: Brett Miller
Funny how millions of hours have been logged with nothing more than HD30.
That it has. Then again, motor oil technology has come a long way from the $0.49/qt SAE 30 we used to get and use.
Joel
It's just old habits that die hard.
Now briggs is saying to go with 5w30 Synthetic up to 104*F outdoor ambient temps. Really! In their loose tolerance engines that are loosing bearings and being replaced left and right?
My take is a 5w30 synthetic with about 1200 ppm for winter use.
A 10w30 synthetic with 1200 ppm ZDDP for all BUT V-Twins
A 10W-40 synthetic Motorcycle oil with 1400 ppm ZDDP for big V-Twins.
my .02
Originally Posted By: rudolphna
So our one year old Briggs 675 has developed a slight knock under load with Craftsman SAE 30. Should I try something else?
Mine does the same friggin thing! has done so from new(Toro 20334)I hear the Briggs & Straton sae 30 is very good oil.
Here's a VOA of B&S SAE 30.
I prefer straight Rotella 30 in my summertime lawn/garden equipment.
