The benefits of changing oil
eastern NewMexico
Hondas gx390 piston ran for many hundreds of hours oil changed every 20 to 50 hours.
This engine was an air compressor before I got it, then a stump grinder, it didn't quite have enough power for the stump grinder and then pressure washer. But it burned too much oil to be a pressure washer and needed a rebuild.
Oils used, whatever 30wt I had laying around then when it was a pressure washer it got Mobil 1 v-twin 20w-50.
