Alternative to 10w-40 in Rotella?
USA
I like using Rotella oil. Unfortunately, the application I need oil for in this particular case calls for 10w-40. I can't seem to find Rotella in that weight. Any advice on what I should use?
Originally Posted by mechjames
Rotella 5w40 or 15w40
This👆.. don't pigeon hole yourself into a single grade. If you're thinking you need a thicker oil for some reason, go with the 15w40... otherwise a 5w40 will work just as well as a 10w40. Heck, even the 15w40 will be fine depending on what the engine originally calls for.
Btw, Valvoline, NAPA, Castrol, Quaker State Advanced Durability are all fine 10w40's.
Originally Posted by blupupher
What application requires only 10w-40 and not 5w-40 or 15w40?
Both the motorcycles in my sig specify 10w-40, that being said I use the 15w40 Rotella in both of them without issue. Most people don't ride motorcycles below freezing anyways so it's a non issue.
Originally Posted by jakewells
tsc carries 10w40 rotella if you have one near.
Never heard of Rotella 10W-40.
Here in Spain we have Shell Rimula 10W-40, Rimula is Shell's HDEO line outside the USA.
Indeed...Shell Rimula R6 (M or ML)....look at its PDS...with cst of 13.1 @100C it is almost 10w30 in grade...
I would use either "your" Rotella in 5w40 /15w40 or 10w30 flavour...
Originally Posted by dlundblad
Originally Posted by OilReport99
Fuchs Titan Cargo Maxx SAE 10W-40
Kendall GT-1 HP 10W-40
Redline 10W-40
Amazon Basics 10W-40
Castrol GTX 10W-40
And last but not least... Rotella 10W-40
https://www.homedepot.com/p/ROTELLA-128-fl-oz-10W40-Motor-Oil-550019907/204999686
Does an HD around you have Rotella 10w40 in stock?
My bad, sorry. I didn't notice it's discontinued. You can buy in Amazon though...
https://www.amazon.com/Shell-ROTELLA-550019897-10W-40-Synthetic/dp/B00HJWM40G
What application (vehicle/engine) calls for 10W-40 ONLY?
Where do you live? (what weather conditions year-round)
Do you use Rotella T4, T5 or T6?
Need more info to offer advice suggestion ...
