Alright who here runs 20W-50 ( or higher )
Many SAE 40s have higher HTHS than some 20W50s especially at post-shear drain time.
I use and have used SAE 40 & 50 in just about everything including XW20 CAFE engines.
That's a good point. In certain climates, like the OPs, why bother with a multigrade at all?
Straight modern group II SAE 40s could be 20W40 or 25W40, and SAE 50, 25W50. Often SAE 30 is referred to reference oil 20W30.
For example "XW20 achieved 4% better fuel economy than the base-line non FM'd 20W30".
Oils:
- Mineral - Penrite HPR 20W60, Castrol GTX 20W50, Valvoline XLD 20W50
- SemiSynthetic - Shell Helix HX7 15W50
- Full Synthetic (PAO) - Castrol Formula-R / Edge 10W60
Vehicles:
- 70's GM Holden Kingswood with 202 cu in (3.3 L) 6 cylinder
- 80's GM Holden Camira with 1.6 L 4 cylinder
- 90's Audi with 2.3 L 5 cylinder
- All my motorcycles and push mowers
With the new century I've now become a Thinnie, and I've started using 15W40 mineral, 10W40 semi-synthetic, or 0/5W40 full synthetic.
I use 20W-50 in my BMW motorcycle, lowest temp has been -3c and it always starts no worries. Next change will be with Penrite V Twin, a POA/Ester, so a bit worried about oil leaks on my old bike. My Volvo has a blend based on 20W-50, and has given it's best economy on that. I often run 20W-50 in my daughters '94 Laser Lynx as it's an oil burner, and used to use it in my other daughters '89 Subaru Omega, but am now using 10W-40 as it's on very short runs and with 20W-50 the lifter tick never stopped, now it's stopped by the end of her drive.
I'm happy to use 20W-50 in anything, anytime.
How many has imploded .... and probably still counting ?
I really can't find any Gasoline rated Monograde oils locally.
Originally Posted By: Gokhan
Why run 20W-50 when there is 25W-60?
Why run 25w60 when there is molasses?
Originally Posted By: FordCapriDriver
Why not SAE 70 + Lucas + Motor honey.
Why use SAE 70 + Lucas + Motor Honey when you can use Roof Tar?
1987 BMW e28 535is. Go to brand of 20w50 has been Castro GTX since I owned a 528e previously that only ran GTX/fram for years. Recently realized it's specs aren't that great and doesn't carry enough zinc/phos for my 535is. I've recently ran a mix of Rotella/Delo 15w40 that worked great in the "winter" months here is Louisiana. Currently running Mobil 1 15w50 and the engine is strong as ever.
SAE 25W-60 and SAE 60 are the highest viscosity grades.
I know but "unofficially" 70 grades do exist in Australia for example.
Do you guys get this Castrol Edge 25W50 in North America ? It's easy to find in Oz.
Its's a Group 2 mineral oil with over a 1000 ppm Zinc, and designed for older big bore pushrod engines. It's API SG rated.
TBN = 8.3
KV100 = 21.0 cSt
KV40 = 204 cSt
HTHS = 6.1 cP
