Boeing isn’t like Airbus - Airbus varies thrust with the throttles in the climb detent. So, you really don’t need your hand on the TLs, you need to pay attention to the TLAs on the engine display.So, if someone pulls the thrust levers back to idle after take off, what would happen like with the seat sliding back theory with the pilot yanking back on the control column and thrust levers ?
If the answer is the thrust will automatically increase even with the TL at idle by accident , doesn’t that make the seat sliding back theory impossible ( aside from the PNF unlikely to let things go that far )?
I am o.k with crash theories as long as they make sense.
Boeing throttles (thrust levers) move, thrust is set by the position of the thrust levers. Tactile feedback is more intuitive and more rapid than looking at tiny display information, hands on the TLs provides that feedback, instantly, instinctively. Hands and feet on flight controls and throttles below 2,500 is mandatory at our company, and that includes on takeoff. Captain’s hand comes off at V1, PF hand goes back on at gear up - the airplane is flying, and the pilot needs to be flying it. The Airbus is designed to be hands off, the Boeing hands on. Different design philosophies, different flying styles.
Boeing AFDS (Auto flight direction system) will not allow you to fly below 1.3 x stall speed. The airplane will add thrust to stay out of that regime. IF the airplane exceeds a certain AOA, you get an “ALPHA” FMA (flight mode annunciation) in the thrust column and the throttles advance until the AOA is under control. This is a 757 feature, but not a 767 feature, which uses a stick pusher to lower the nose, but the AFDS will still add thrust at 1.3 stall, and extend leading edge devices at critical AOA, it just won’t go into “ALPHA” mode.
In the 787, you get a very similar thrust response, as well as all the other stall indications. The airplane adds thrust if you get slow, and extends leading edge flaps at a certain AOA. I don’t have the space, here, to discuss all of the envelope protections, but they are extensive, including both flight control and thrust responses and protections.
I’m typed in the A320, 747, 757, and 767, and in reading the 787 flight manual, it’s more sophisticated than the A320, offering more tactile feedback, more envelope protections, more flight control features. It handles yaw on an engine failure for example, and uses aileron and spoiler to increase pitch when landing flaps are extended if the pilot fails to do so, in order to better position the airplane for landing. Again, I can’t regurgitate hundreds of FM pages, but the airplane itself is very well thought out. It’s the latest generation of flight control systems - it’s the apex of airliner design and thinking - and I suspect the A350 is similar. The A320 is the previous generation, just as the 757/767 is the generation prior to that.
Airbus TL at idle results in idle thrust. Boeing TL at idle results in idle thrust. That’s how both airplanes are designed. If you hit alpha floor in the Airbus - you will get TOGA thrust, regardless of thrust lever position, IIRC. I don’t see where the Boeing has an Alpha Floor - type feature, but I haven’t read the entire FM, yet, and I know that the 757 adds thrust above a certain AOA, as does the 767, and I suspect that the 787 is similar - but the throttles move in order to add power - unlike the Airbus.
IF someone is using the TLs as a grab handle because their seat slid back (and I think this theory unlikely), then both airplanes will be at idle (with the alpha floor exception above, which is inhibited below 50 feet in the Airbus).
Both airplanes offer envelope protections that would keep the airplane below stall AOA, which would explain why the airplane was 10-15 degrees ANU all the way to the crash - it was flying slow without quite stalling.
The real question - where was the thrust?
Not the thrust levers, per se, but how much power were the engines producing?
As every Naval Aviator* knows - stick input controls airspeed, and power controls rate of climb/descent.
This airplane was descending, and not stalled - the only explanation was low power output.
*First explained in the outstanding book, “Stick and Rudder” by Wolfgang Langewische in the 1940s. His treatise remains one of the best references on how airplanes fly ever written.
