Found this in the B787 manual:
Suction Feed
When main tank fuel pump pressure is low, each engine can draw fuel from its corresponding main
tank through a suction feed line that bypasses the pumps. As the airplane climbs, dissolved air is
released from the fuel in the tank due to the decrease in air pressure. This air may collect in the suction
feed line and restrict fuel flow. At high altitude, thrust deterioration or engine flameout may occur as a
result of the fuel flow reduction.
The dissolved air in the fuel tank eventually depletes after reaching cruise altitude. The depletion time
is dependent upon airplane altitude, fuel temperature, and type of fuel. Once the dissolved air is
depleted, the engine should effectively operate on suction feed.
Fuel pressure can be provided from a main tank with operating fuel pumps to both engines by opening
the fuel crossfeed valve. Continued crossfeed use results in a progressive fuel imbalance.
Fuel
AI search about B787 suction feed:
B787, suction feed, also known as gravity feed, is a method of fuel delivery where the engine draws fuel from the tank using the engine's suction without relying on fuel pumps.
