I happened to catch this awful event on the news when I got up this morning.
There is already a long thread on this accident on one of the dedicated Av sites.
It is only around 3700 NM AMD to LGW, so the aircraft would have been a long way from full tanks, although AI could have dispatched the flight with tankered fuel, since fuel refined from Russian crude is certainly cheaper in India than Jet A would have been at Gatwick, although it does cost fuel to carry fuel.
The departure airport is only a couple of hundred feet MSL, but it was quite warm, around 40C, or just over 100F.
Speculation is that the crew elected to take off from the point where they entered the runway from an intersecting taxiway, leaving about 6000' available but even if true that shouldn't have been a factor, since they did achieve 174 knots and an altitude of 625', so around 400' above ground level.
It's also speculated that there may have been a power loss on one or both engines, or that the crew retracted flaps when they meant to retract the gear. The available video (with audio) is far from clear or conclusive as to aircraft configuration or power, so people seem to be seeing what they want to see, but the black boxes will tell the story.
At this point, who knows?
We must await the results of the investigation to follow to learn what really happened to doom this flight.
A horrible accident for all aboard and on the ground at the point of impact.
