I'd watch that!
500K subscribers the first year.
I'd watch that!
There are only two likely reasons IMHO it was unable to climb after reaching 400 feet above ground and losing power on both engines is certainly one of them considering the accident is very unusual.Who is saying that? I'm not doubting you, it's just that thus far I haven't read anything in regards to both engines failing. Do you have a link?
Most likely it did, my hunch is that there were numerous alarms going off at once. From the sound of several people Air India wasn't exactly on top of maintenance and a Boeing 787 is really cutting edge and sophisticated piece of equipment.Hard to believe a modern jet like the B787 won’t warn pilots if the flaps don’t travel to the full, selected position.
A clue might lie in the RAT.There are only two likely reasons IMHO it was unable to climb after reaching 400 feet above ground and losing power on both engines is certainly one of them considering the accident is very unusual.
It’s rare to lose one engine, to lose enough power making it impossible to climb would mean losing power on both engines and that’s even more rare.
I am not saying it’s fuel contamination but the only time I have heard of planes losing power on both engines is because of fuel contamination ( excluding running out of fuel obviously or birds ).
It’s more than capable of flying on one engine ( but the gear is supposed to be up ) after take off if it was just a normal engine failure on one side. That said, it’s certified to lose an engine at V1, rotate , cross the end of the runway no lower than 35 feet , select the gear up ( most drag on the aircraft other than full flaps which planes don’t take off with ) and still be able to climb.
I don’t consider it proof until verified more but there ( aviation herald ) are reports the crew declared Mayday and something about losing power/lift FWIW.
Read about the B737 that crashed because the crew forgot to select the gear up after losing an engine after take off.
I am not suggesting this is what happened with the B787 ( it’s got a lot more extra thrust ) but it shows you what can happen.
https://en.wikipedia.org/wiki/Air_Algérie_Flight_6289
Every modern plane will warn pilots if the slats/flaps don’t fully travel to the selected position.Most likely it did, my hunch is that there were numerous alarms going off at once. From the sound of several people Air India wasn't exactly on top of maintenance and a Boeing 787 is really cutting edge and sophisticated piece of equipment.
Incredible airmanship.There was a near-miss with an L1011 over 40 years ago in which a mechanic failed to install the o-rings on the chip detectors on all 3 engines when re-installing them, and the aircraft lost all 3 engines as a result, about 20 minutes after takeoff.
They were able to get one of the engines re-started in order to land safely.
Not saying that's what happened in India, but I thought of it as I was thinking about how this could have happened.
https://en.wikipedia.org/wiki/Eastern_Air_Lines_Flight_855
Wow, that's a lot of T shirts500K subscribers the first year.
There has been new audio released of the incident, a deployed RAT has a very unique sound and it seems to be present in the audio clips. The RAT deploys automatically should both engines fail. It provides enough electric and hydraulic power to keep the aircraft flying, but not enough to retract the gear. A closer look at the main gear shows that it might possibly have started to retract before losing hydraulic power, it doesn't look to be in the normal down and locked configuration.A clue might lie in the RAT.
Was it deployed or not?
The survivor's account would seem to corroborate a brief loss of cabin electrical power after he heard what he described as a loud bang.
Compressor stall? We should be able to see some evidence of that in the various videos and I don't think we do.
Also, this man was obviously badly traumatized by his experience, so his account may not be entirely reliable.
I can't speak about the B787, but you can take off with the wrong flap setting on the Airbus ( you can't take off with no flaps though without a warning ).There has been new audio released of the incident, a deployed RAT has a very unique sound and it seems to be present in the audio clips. The RAT deploys automatically should both engines fail. It provides enough electric and hydraulic power to keep the aircraft flying, but not enough to retract the gear. A closer look at the main gear shows that it might possibly have started to retract before losing hydraulic power, it doesn't look to be in the normal down and locked configuration.
The likelihood of taking off with the wrong configuration or inadvertently retracting the flaps instead of the gear in an aircraft as modern as the 787 is extremely small. Everything now is pointing towards loss of power in both engines which is also very rare. We'll have to see what's on the CVR and FDR before having any real answers, fortunately those are also top of the line units.
According to a Flightglobal article a Qantas 787 in 2021 couldn't retract its landing gear due to landing gear pins being left in place (Due to maintenance I assume). It also stated that " A flight crew received a warning that the main landing gear had not retracted even after attempts to toggle it in the UP position." It sounds like the 787 will tell you when you forget.Every modern plane will warn pilots if the slats/flaps don’t fully travel to the selected position.
That said, there is no warning if pilots forget to put the gear up ( just for information purposes ) unlike if they forget to put it down for landing.
So both engines run off the same tank?I am not saying it’s fuel contamination but the only time I have heard of planes losing power on both engines is because of fuel contamination ( excluding running out of fuel obviously or birds ).
Does the RAT make a slamming noise on these when it deploys? I was in the jump seat of a CL601 when we manually deployed it for an inspection and you certainly knew when it deployed.A clue might lie in the RAT.
Airliners are refueled from a single point and the fuel is distributed to tanks located in the wings and center section of the fuselage, the center tank is usually only filled for long-duration flights. The left wing tanks supply the left engine, and obviously the right side handles the right engine. There are also cross-feed lines and pumps so fuel can be transferred from one wing to the other as necessary.So both engines run off the same tank?
Or your saying both tanks were possibly contaminated by filling from the same source?
Pilots will not get a warning if they forget to select the gear up but they will if they select it up and it fails to go up due to mechanical problems.According to a Flightglobal article a Qantas 787 in 2021 couldn't retract its landing gear due to landing gear pins being left in place (Due to maintenance I assume). It also stated that " A flight crew received a warning that the main landing gear had not retracted even after attempts to toggle it in the UP position." It sounds like the 787 will tell you when you forget.
Qantas 787 landing gear pins left in place
A video from the previous flight was filmed at the gate saying that the Air conditioning was nonfunctioning, the seat back tablets seemed to be unresponsive as well.
Captain Steeves YouTube channel was able to obtain the original footage of the accident. It's worth a watch as its much clearer. Most of the footage was from a camera that recorded the original cellphone video. He shows what he thinks is the rat deployed and you can hear it according to him. He said the rat will deploy if there's an electrical failure, hydraulic failure or dual engine failure.Pilots will not get a warning if they forget to select the gear up but they will if they select it up and it fails to go up due to mechanical problems.
Not a fan of his channel but, being open minded, I just watched it.Captain Steeves YouTube channel was able to obtain the original footage of the accident. It's worth a watch as its much clearer. Most of the footage was from a camera that recorded the original cellphone video. He shows what he thinks is the rat deployed and you can hear it according to him. He said the rat will deploy if there's an electrical failure, hydraulic failure or dual engine failure.
I am unfamiliar with the B787 fuel system but on the A320, if the centre tanks are full ( longer flights ) , both engines get fed from pumps in the centre tank until the tank is empty then each engine is fed by respective side wing tank. Left engine, left wing tank, right engine, right wing tank.So both engines run off the same tank?
I am surprised - its not a redundant setup in that configuration. So I guess fuel is on the list of possibilities.I am unfamiliar with the B787 fuel system but on the A320, if the centre tanks are full ( longer flights ) , both engines get fed from pumps in the centre tank until the tank is empty then each engine is fed by respective side wing tank. Left engine, left wing tank, right engine, right wing tank.
