- Joined
- Feb 5, 2023
- Messages
- 244
Okay, now I need to figure out the air filter I will be using. From what I can see it looks like The only filter available that will fit in the OEM airbox is unfortunately a K&N. After having read through the site for many years before posting, I know that the efficiency isn't very high on K&N's. I've asked around on the forums a little bit and one suggestion that was brought up was this box.
https://jmbperformance.com/product/viper-cold-air-setup-4/
In past cars I never used any aftermarket cold air intake setups before. I know some are well designed and others are not. Also, are cone filters that would be used on this universal in the connection ( meaning, if there's a cellulose media cone filter made by someone like wix or fram, would it fit on the same connection as one designed for this just as well as a K&N or AEM aftermarket filter type)?
I guess at the end of the day, what is going to be the most efficient filter setup that I could go with for this car as I want to keep the engine pampered with as clean air and clean oil as possible? For the fact that I'm not going to drive the Viper on a daily basis by any stretch and just talk car shows or for just a casual drive never on the track in Midwestern corn and coal mine country, should I just get the K&N and not worry about it?
