Hello all..... as an avid lurker here for years and finally a member a few months ago, I still have questions......
I have two commercial grade Kohler efi air cooled engines. One on a generator and on a zero turn. Years ago I made the switch to 0w30 oils and have never looked back. Just on these two engines plus my efi mule, when I switched from conventional 20w50 factory branded oil to the Mobil 1 0w30 I immediately noticed how much faster they spun over and how much less lifter rattle they had when cold...... the engine AIC MOTOR had to step down the idle since they were even idling higher......
MY CONCERN IS that these two air cooled engines run on average 230 degrees as observed with my infra red gun taking readings off the oil filter. I suspect they may run as high as 275 degrees in the hot Texas summers...... the engines do not use any oil whatsoever and at 100 hrs the oil looks pretty good still. I read many studies on how 30wt oil actually removes heat better than 50wt oil. My concern is that at high temp such as 275 will the 30wt synthetic oil cause harm in the long term?
I guess the only real way to tell is to do some UOA testing?
I have a Honda eu2000 generator that has has mobil 1 0w30 after the 8 hour mark of a motoman break in that has right at 1000 hrs and doesn't use any oil between 100hr OCIs'.
Is there any significant studies done that synthetic actually make an engine last longer? I know folks that run nothing but shell rotella and their stuff lasts forever also but they do have to add oil sometimes whereas I dont......
I know that a majority of engine wear is at at startup and I do feel alot better knowing that thinner oil flows faster when ambient temp. But again is there ever been real world studies besides biased wear tests that only test one function like film strength?
Was thinking about switching everything over to 5w-40 Mobil delvac 1esp since it's a stout diesel oil with extended OCI capability....... I'm really fixing to start running these engines hard under commercial use and want to get the best protection and longevity I can.
I can get the Mobil 1 delvac 5w-40 esp cheap from orielly since i have a commercial account and the manager sells me a lot of stuff at cost.......
![[Linked Image] [Linked Image]](http://i897.photobucket.com/albums/ac174/justinmargist/SmartSelect_20181121-112813_Chrome_zpszsslhiuq.jpg)
