Originally Posted By: Nick R
What IS the relationship between air temperature and engine temperature in small air cooled engines? I mowed our lawn today at 33 degrees. It took 3 pulls to start, but it ran perfectly for the 3 hours it took to finish. And then I dump some stabil in it, and put it up for the winter.
For a given load, its more or less a fixed offset. You put a certain amount of heat energy into the metal per second of operation, and then the cooling fins have a thermal resistance in getting the heat from the metal to the air. Energy departs the engine as at a rate determined by that thermal resistance (fixed) and the difference between the metal and air temps. When the metal gets hot enough that the rate of heat flow out equals the heat flow in, the engine temperature stabilizes. So holding everything else fixed, the difference in temp across the cooling system is constant so if you lower the air temp around the engine, and the engine metal temp lowers the same amount to a first approximation.
One thing to consider is that air is less dense at higher temps so the cooling system becomes less efficient. That means that the spread between the air temp and the engine temp actually gets a little bigger as the surrounding air gets hotter and smaller as the air gets colder and denser.
