Originally Posted By: Surestick
Originally Posted By: boraticus
There's quite a bit of difference between an aircraft cruising at 180 mph or more in -40F temperatures and a lawn tractor working relatively hard pushing snow.
We're not breaking new ground here. Engines are designed to perform certain tasks. Engineers build in components/characteristics for them to perform and survive. I doubt very much that throwing a rag over the cooling air intake would be considered as being innovative engineering. Particularly when a seat of the pants thermometer is being used to measure engine temperatures.
Sack the sack.
Most air-cooled piston-powered airplanes don't fly high enough to be at -40C temps, those that do actually tend to have cooling issues due to the thinner air not carrying as much heat away.
Most air-cooled piston-powered airplanes also have a winter-kit that restricts cooling air and is used in colder locations during the winter.
I'm having a bit of a problem making the leap from airplanes to lawnmowers?
The similarity eludes me. Sure, both might use air cooled engines but they're worlds apart in their application.
Sack the sack.
