I'm changing the oil in a vertical 80 gallon air compressor. It's a Northstar brand. It calls for sae 30 non detergent compressor oil. I have some oil for it made by Coastal(Warren). It is sae 30 ISO 100 non detergent motor oil. The API rating on the back is SA. It says contains no additives. When my dad changed his, he used Napa 30nd and it was SB rated. Is there much difference between SA and SB in a compressor? Will SA be OK? Or do I need a specific compressor oil?
