oil for an air compressor
Taxachusetts, USA
Ive got a new to me Hitachi air compressor, model EC 12. First thing Id like to do it change the oil. Attached photo shows that it requires 5W-30, FS. Im wondering if I need to buy compressor oil or would any old FS that meets the spec be OK? I have loads and loads of FS 5w-30 lying around.
I live in New England, and will use this compressor in cold weather/winter.
TYIA!
I don't see it being an issue if the seals/gaskets are worn maybe you'll see some seepage. Otherwise should be fine.
TYIA!
did you typo the pic says 5w50, also seems to show 15w40 is ok for warmer weather.
If I am going to keep something long term and it is important to me, I use the mfg. recommended product, in this case hitachi 19210b is a special non-detergent oil designed for air compressors and reduces carbon build up, valve cleanliness, etc..
https://www.ebay.com/itm/272276549435?chn=ps&mkevt=1&mkcid=28&google_free_listing_action=view_item&srsltid=AfmBOoq8g86htjo_Cg4bK3zaRPk3S1WKG6RHqn4CgXBBtflHNXRZnnrHFco
My 45 year old compressor is still going strong on it's recommended Mobil Rarus 427 ashless compressor oil changed annually.
If it is going to be kept in an attached garage I would use the recommended 15w40 HDEO for the ease of getting the oil. SuperTech makes a good 15w40. If you are concerned about the cold, then you could switch to 5w40 HDEO. It is interesting it does not specify compressor oil which is usually non detergent straight weight oil.
Thank you for the link. I ordered 2. I appreciate you posting exactly what I needed.
