air compressor keeps popping oil fill plug out!
Michigan
When the compressor kicks on to charge the oil fill plug pops out now. Seems to be holding air fine. Why does this happen? It is a 5hp 8 gallon Campbell Hausfeld.
Is there a lot of hours on it? Some small portables have breather holes drilled through the oil filler cap, or a separate breather elsewhere on the crankcase. I'd look for clogs/plugs @ the breather.
Other than that, it could be worn rings or reed valves causing excessive blowby.
Joel
