Adding R134A to the AC system
Near the beach in Delaware
Does anyone worry about the slight about of air that is in a AC high/low manifold when you connect up the high and low pressure sides and then add R134A?
Even if you get a can of R134A and a 8" hose and low pressure adapter, there is a tiny amount of air in that hose that I assume gets pushed into your AC system?
Or do I worry too much about unimportant things.
I always worried about it. I crack the low side fitting on the manifold to at least bleed the charge hose. If you have pressure in the system as well as the charge hose (a cylinder/can attached) then it is possible to completely bleed the gauges and hoses before filling/topping a system. Old style R-12 always got bled before hookup.
It is very important to bleed your hoses, before connnecting them to your car. Air , and especially moisture, will most certainly cause a decrease in AC performance.
This is standard practice.
Yes, you should worry about it. All instructions I've ever read require cracking the valve open just a bit for a short while to displace the air in the hoses with refrigerant. All these "little things" add up to a job well done.
How about if you use one of those short hoses that only has a low pressure fitting a gauge and can tapper valve. Not sure how one would purge that short hose.
Same as any hose, just less air to displace. Or conversely, less air to worry about if you don't purge the short hose.
Take some needle nose pliers and pinch the middle valve on the fill end after turning the feed line on and then purge away.
