Does anyone worry about the slight about of air that is in a AC high/low manifold when you connect up the high and low pressure sides and then add R134A?
Even if you get a can of R134A and a 8" hose and low pressure adapter, there is a tiny amount of air in that hose that I assume gets pushed into your AC system?
Or do I worry too much about unimportant things.
