Added 1 3/4 qts Dex VI to Jeep....Oops?
USA - Coast to Coast, Border to Border
I screwed up. I pulled the transmission pan off the Jeep, and changed the filter. Got everything bolted back up, was adding transmission fluid, and noticed I accidentally grabbed 2 quarts of Dex VI off the shelf. I also added about 2 quarts of the ATF+4, as well as 12 ounces of Lubegard Red. Is this going to hurt anything? The total fill is 8.8 quarts, with 1.8 quarts being Dex VI.
I doubt its going to make a difference being such a small amount. Dex 6 has a different friction property but that little shouldn't matter enough to hurt anything.
I'm a nut when it comes to proper fluids for Chrysler products and I wouldn't be worried about it either. Dex6 and ATF+4 are not all that different, and you've only got about 10% Dex 6 in there anyway...plus you added Lubegard Red which is the bomb IMO I also use that religiously... so I'd say forget about it.
