- Joined
- Sep 28, 2002
- Messages
- 39,793
The flow will take the shortest path to the interior. Naturally if there's flow in excess of what can be passed easily through the available space in the convolutions of the pleats, it will probably bias itself toward the holed end of the media. What that will eventually do is saturate that part of the media first, biasing it back toward the blanked tube part of the media.
That's just speculation, mind you. If it did occur that way it would be on some curve, and would surely be altered as time/mileage/loading progressed. One the media is blanked at a certain point, the other the tube.
But think of a regular Swiss cheese center tube. The same theory applies. The flow will want to take the shortest pathway out of the filter. Why descend all the way to the bottom of the filter? Much shorter to just "dip in and dip out" right at the end plate.
Except for something like a Spin-Flo, that's probably what occurs. The flow will shear and get slower as you descend into the can, with the end of the can having the least movement and the open end having the most.
That's until the upper level of the media gets saturated; making the lower/deeper sections more appealing to flow.
If you see what I mean...
What I'm saying is that there isn't the advantage one would think with the full depth perforated tube. One the media blanks off with age, the other part of the tube is blanked from the get go.
