Adams Graphene Advanced Ceramic Spray.
Coated every possible painted surface I could. Took a while as I've never used ceramics before but it was well worth it. Truck doesn't even look two years old.
Thanks. Definitely sold on the product line. Have the Graphene boost as well for touch ups.
I thought about trying that. I read good things about it. Very hydrophobic.
If I ever move into the world of doing a graphene/ceramic coating I would give this one a try. I hear it’s a lot more user friendly than the traditional coatings (the ones that come in a tiny bottle) and that the cure time is shorter as well (which is important for me if I was doing the Civic since it doesn’t have a garage spot to sit inside for a few days after the coating)
Certainly. Was always afraid of ceramic coating as I've heard the stories. Cure time only 4 hours which is great. I like they use a tracer dye to indicate when to wipe off.
The coating lite products and even some of the new coatings are easier to use than waxes believe it or not . Can Coat is wipe on/wipe off.
I'm more impressed about what didn't get the adams spray. Jeep looks brand new underneath. How do you clean it, foam cannon the underside a bunch then pressure wash?
Actually just hand washing and spray detailer. Normally don't drive it in the rain very much.
So you probably don't do this?:
I plan to give Gyeon Can Coat Evo a try this fall. Now I might have to consider Adams? Did you do the full paint prep recommended by most of these coatings?
Looks great. I'd be curious how it holds up. I tried their graphene glass coating and it lasted like 5 days.
Been using Adams Advanced for a few years. Great stuff. Paint prep is key. I use Prep All and get all the grime out. Lasts a long time. After it sets up, I hit it with Jescars or Collinite 845 for added protection. I do this in the fall before the snow and road salt starts. Salt Belt is rough on paint, amongst the underbody. Gets into everything. Just one bottle of Adams goes a long way too :)
