Got a B16 code on the maintenance minder at 11300 miles. This means oil change and rear diff fluid change.
A bit of a pain due to location, but quite an easy job.
11300 miles seems a bit early for changing the rear diff fluid. For people that own Acuras with SH AWD is this the usual interval? The used fluid looked clear and the magnetic drain plug had only a very small amount of fine particles attached.
By the way, I used Acura Dpower steering fluid fluid per the manual. I can't seem to locate a synthetic alternative.
