Got it back on Thursday after having the tranny and radiator replaced because the radiator cooler line failed due to corrosion and inturn mixed tranny fluid and coolant and the tranny then failed.
Drove it for a few hours Friday and everything seemed fine and then thought I would check everything out fluid wise Saturday morning. Noticed that the tranny fluid level looked good and was clean and right at the full level.
Then checked the radiator overflow bottle and saw that the coolant was very dark almost black/red-should be clean blue coolant... Oh nuts. Then took the radiator cap off and saw a very brown/red gunk thick fluid under the cap. Guessing that they obviously did not flush out the cooling system sufficiently when all the old radiator tranny/cooler let go that caused the original tranny to fail and got old tranny fluid and coolant mixed into the cooling system
I have a call in and hopefully they will take it in Monday and finally flush out ALL the crud and get it right... I am hoping they did not ruin anything by not flushing it enough. They stated on the invoice that it was flushed several times but I seem to doubt that... Can I drive this MDX without causing more damage?
Could anything get ruined by me driving this vehicle? Could the heater core and new radiator be ruined? Any engine/coolant seals/water pump, etc be messed up because of the tranny fluid in the coolant passages? Any way to make sure they clean this clean out right? Thanks...
Big question is can I drive this MDX without damaging anything else?
