quote:
Originally posted by dave1251:
daemonite
Member
Member # 6689
posted 22 August, 2005 15:12
quote:
Originally posted by mdocod:
idle speed should be adjusted automatically by your idle control motor/etc>... if your idle speed has changed- then it is not the fault of oil or filter, it is related to other systems on the car. No "check-engine" lights???
differences generated by oils and filters are not something you will be "wow, look at that" about.. they are within 0-2% margin, most people will never notice anaything.
i notice differences at idle speed during warm up with 10w30/5w30.
not really higher or lower but in the time it takes to drop high revs @ idle to normal idle
Posts: 144 | From: Fremont, CA | Registered: Apr 2005 | IP: Logged |
Could this be that your 5w30 sheared down to a 5W-20?
