ACDelco PF64 - C&P - Torn Media!
Originally Posted By: smithph
Complete KNOB question on my part. Does anyone have a source document from ACDELCO on the UPF64R and PF64 oil filters. I tried to look them up on the ACDELCO site and could not find any Delco published specifications sheets.
AC-Delco is secretive to consumers about this. For most people, its good enough to say "this is an OEM oil filter, so trust us".
I've only found some basic info on vendor sites like
https://www.oreillyauto.com/detail/b/dur...er/pf64/2494117
And then GM revealed some info on bypass specs on their PF64 and PF63E oil filters:
"Today's engine has very tight tolerances, two stage oil pumps and high flow lubrication system requirements. The proper match of oil filter to engine application is more important than it has ever been in the past. The use of a replacement oil filter with an internal bypass valve opening pressure specifications of 15 PSI (100 kPa) or less, allows debris to circulate in the engine causing damage to bearings and other tight tolerances areas, which may result in premature engine failure.
The oil pressure was increased to accommodate these tighter tolerances. As a result, the oil filter specifications of the production oil filter and the service oil filter were also improved to meet the new engine requirements.
Beginning in 2012, the oil pumps began to regulate main gallery feedback instead of pump out pressure. This means that the oil pump now does not begin to regulate until pressure is built up to the main gallery. This change reduces the amount of time it takes to provide oil to the engine bearing and lifters during extreme cold start conditions.
Main gallery feedback oil pump control systems are present on the following engine families which use Spin-on oil filters: Small Gas Engine (SGE), Large Gas Engine (LGE), High Feature (HFV6) Gen2 and Small Block Gen5 gasoline engines. These engines with the main gallery feedback oil pump control systems are factory built with an ACDelco® oil filters.
Important: The PF64 and PF63, which is commonly confused by many in the automobile service industry as an ACDelco® PF48 and/or PF48E , because both oil filters have the same appearance and oil can size. However these oil filters are not the same and have different internal bypass valve opening pressure specifications (PF48/PF48E = 15 PSI (100 kPa), PF64/PF63E = 22 PSI (150 kPa).
Note: Any aftermarket filter must also have an internal bypass valve opening pressure specification, element integrity, filtration performance, media particle trap specification and burst strength that is equivalent to the ACDelco PF64/PF63E filters. "
--- from a GM memo about our oil filters, and from https://bobistheoilguy.com/forums/ubbthreads.php/topics/4627091/Ecotec_5.3_oil_filter_bypass_P
That base plate fell on the road when the dumpster arm jettisoned the trash. I found it several days later and cars had beaten it into the asphalt ... never bent.
Wish they would also run better um ... they don’t seem to fail ... media is tough
Originally Posted By: oil_film_movies
Note: Any aftermarket filter must also have an internal bypass valve opening pressure specification, element integrity, filtration performance, media particle trap specification and burst strength that is equivalent to the ACDelco PF64/PF63E filters. "[/i]
Key words "element integrity". ACDelco's PF64 failed there.
Originally Posted By: goodtimes
There is no "if." I show where. It begins as predicted.
You should play the lottery.
