How tight should a person tighten the tension on accesory belts like water pump/alternator? I just got a new belt that drives the water pump and alternator. My Haynes manual says that you should measure the deflection in the middle of the belt (when firmly pressed) and it should deflect only 1/4 of an inch if the belt is less than 11 inches long between pullies. This is assuming you don't have one of those tension gauges. I measured it and tightned everything up and it seems too tight, and my alternator is squeeking. It says for the tension gauge that a brand new belt should be have 180lbs of tension Vs. 100 for a used belt. You guys have any secrets for belt tension? I know if you have them too tight you can mess up the bearings in the water pump and alternator.
[ May 19, 2003, 11:14 PM: Message edited by: Drew99GT ]
